    Home ยป Laowa Argus 33mm f/0.95 CF APO Review
    Sony E (APS-C)
    KlausBy KlausFebruary 3, 2022Updated:June 3, 2024
    Review by Klaus Schroiff, published February 2022
    There is a general notion that full-format is the way to go for shallow depth-of-field photography. Of course, there have been many attempts to defy the limitations of smaller formats with f/1.4 and f/1.2 lenses. However, even this isn’t enough for some smaller Chinese players. Notably, Laowa got serious about it with a set of f/0.95 “Argus”-branded lenses. Now, in all honesty – lenses around the f/1 mark tend to be relatively poor in terms of performance – or let’s call it “full of character,” as Youtubers describe it. The new Laowa Argus 33mm f/0.95 CF APO may be a little different, though. The name contains the “magical” word APO which points towards a high correction of optical defects. So let’s find out whether this is more than just marketing-speak. Priced at $500USD, the Laowa lens is also ambitiously positioned for a fully manual lens. It is available for all APS-C format mirrorless systems.
    Laowa has lifted the build quality of their lenses to pretty high standards over the last few years, and this also applies to the Argus. The lens barrel is entirely made of metal with a nicely dampened focus ring and a step-less aperture ring. There is no weather sealing, but the internal focus mechanism helps against the elements to some degree, at least. It’s not a tiny lens and quite heavy at 580g. A curious little detail is the provided square-ish-shaped lens hood and the accompanying slide-in lens cap (which is slightly shaky when attached). While not unique, it is a rare sight; we quite like it.
    As mentioned, the Argus is a fully manual lens so there’s no EXIF data, no camera-controlled aperture and, of course, no autofocusing. Manual focusing is very nice, thanks to a very long focus throw. Video makers will undoubtedly appreciate this.
    Equivalent focal length (full-format)“50mm”
    Equivalent aperture (depth-of-field, full-format)“f/1.45”
    Optical construction14 elements in 9 groups inc. 2xED, 1x aspherical, 3xUHR elements
    min. focus distance0.35m (max. magnification 1:?)
    Dimensions71.5x83mm
    Weight580g
    Filter size62mm
    Hoodsquare-shaped (bayonet mount, supplied)
    MountsFujifilm X, Sony E, Canon M/R, Nikon Z
    The Laowa Argus 33mm f/0.95 CF APO can’t take advantage of auto-correction thus it has to rely on its original capabilities. Most Laowa lenses don’t have issues with distortions and the Argus is no exception in this respect. At just ~0.27%, they aren’t really noticeable in real life.
    While image distortions are negligible, the same can’t be said about vignetting – although this can’t come as a surprise given the ultra-large aperture. At f/0.95, the light-falloff is over 2EV (f-stops) which is very high by APS-C standards. Stopping down to f/1.4 sees a noticeable improvement but it’s only well-controlled from f/4 onward.
    The ambitious optical design shows some benefits with respect to the resolution potential. The quality is pretty impressive, even at f/0.95. The broader center is on a very good level and only the corners soften without being terrible. Stopping down results in a gradual improvement along with the aperture. A significant boost occurs at f/1.4 with very good quality across the image field. The peak performance is reached around f/2.8 already. The broader center is sharp as a tack here and the outer image field stays just short of excellent quality. Diffraction impacts the quality at smaller aperture settings but this is only getting relevant beyond f/8.
    The field curvature is marginal. The centering quality of the tested sample was mediocre.
    Below is a simplified summary of the formal findings. The chart shows line widths per picture height (LW/PH) can be taken to measure sharpness. If you want to know more about the MTF50 figures you may check out the corresponding Imatest Explanations.
    The APO designation in the lens name promises very low color fringing. While we agree that lateral CAs are very low, they are still present with an average pixel width of around 0.5px at the image borders.
    The talk about resolution etc is exciting but the main reason for investing in such a lens is shallow depth-of-field photography so let’s check out the quality of the bokeh (rendering of the out-of-focus blur).
    The Laowa Argus 33mm f/0.95 CF APO suffers from an unusual effect concerning out-of-focus highlights. You may notice a couple of aspects in the sample crops below. The inner zone of the discs is exceptionally smooth. So that’s great. But you may also notice that there is a strange vignetting effect at the top and bottom. This is more obvious in the sample images further down below. This effect is only partially related to the lens itself, but the camera also plays a role in this.
    On Sony APS-C cameras (and notably the A6300, which we used for testing here), the sensor is deeply recessed – see below. The problem is that extremely angled, out-of-focus light-rays are partially hitting the “walls” of the sensor housing, causing the top/bottom vignetting in the highlights. We verified this theory by mounting the lens on a full format Sony camera. This mechanical vignetting is NOT present in these images – simply because there is more space. Most likely, this effect is limited to all (?) Sony APS-C E mount cameras but that’s nothing that we can guarantee.
    The effect is gone from f/1.4 simply because the smaller aperture crops the vignetting. You may also notice that the highlights are getting more distorted to cat eyes towards the borders but this is a more common mechanical vignetting effect and corrected the more you stop down.
    f/0.95f/1.1f/1.4f/2
    As far as the general blur is concerned, the results are less complicated. The blur is relatively smooth in the background (shown to the left) albeit you may spot an unsymmetrical rendering and reduced contrast. This is also present in the foreground blur which is also a bit rougher.
    While this may all sound slightly negative, the issues are far less evident in real life – see the sample image section. At least in our samples, the highlight vignetting is hard to spot unless you are looking for it. Undoubtedly, this can be more obvious in scenes where these highlights are more dominant. Overall, the bokeh is still pretty pleasing because of the sheer amount of achievable out-of-focus blur, hiding some imperfections.
    A “true’ APO lens shouldn’t just correct lateral CAs (on the focus plane) but also axial/longitudinal CAs (on the Z-axis). While Laowa has been able to do the magic in the past, the correction isn’t perfect this time. Below, you may spot the purple tint in front of the focus zone and the green one beyond. This isn’t dramatic and low in the grand scheme of things but it remains visible from f/0.95 to f/1.4, much less so at f/2.
    As a side note, you may notice that the focus point shifts to the rear when stopping down (without changing the setting). So there’s a fair amount of RSA (Residual Spherical Aberration). This is something to keep in mind at close focus distances and large apertures where you should stop down the lens PRIOR to focusing.
    f/0.95f/1.1f/1.4f/2
    The specs of the Laowa Argus 33mm f/0.95 CF APO (to the left below) are pretty much unique, so it has no competitors in the narrow sense. However, at least the Samyang 35mm f/1.2 ED AS UMC CS comes close. It is a little cheaper, which you can expect given its more moderate max aperture. It has a simpler design, so it may not match the Argus at f/1.2 at least. The Sigma 30mm f/1.4 DC DN (to the right) is a more mainstream lens. Unlike the other two, it’s electronically integrated and has an AF. This alone makes it more appealing for a broader audience – at least among photographers. Some video makers prefer manual lenses, though. The Viltrox/Tokina AF 33mm f/1.4 (not shown) also comes into mind when including slower lenses.
    7.5
    The Laowa Argus 33mm f/0.95 CF APO is trying the seemingly impossible by providing shallow depth-of-field capabilities similar to full-format to APS-c class users. And, surprisingly, they succeeded in this quest - mostly at least. The optical performance is on a high level, even at maximum aperture. The broader center is sharp straight from f/0.95 and the borders can keep up nicely. Only the corners are a bit soft. The background contrast is slightly reduced at this setting but this can be boosted via an imaging tool. Stopping down to f/1.4 results in quite a lift in quality even in the corners, and the peak performance around f/2.8 is very impressive indeed. Image distortions are very low and nothing to worry about. As you might expect the vignetting is very high at large-aperture settings. Lateral and axial CAs are well controlled, although they aren't entirely as absent as the "APO" designation may suggest. RSAs are also something to be aware of. The technical quality of the bokeh is a bit of a mixed bag. Depending on the camera that you use, out-of-focus highlights can suffer from an odd mechanical vignetting effect up to f/1.4 and there are imperfections in the general blur as well. However, this isn't quite as obvious in real-life conditions simply because the lens can produce an immense amount of out-of-focus blur in the right conditions at least. Flare can also be a weak spot so better mount the lens hood when shooting.
    The mechanical quality of the Argus lens is, again, impressive. The all-metal construction feels very reassuring and the dampened control rings are a joy to use. The internal focus mechanism is appreciated and we are also a fan of the new hood design. It's not all glory, though, because there's no electronic coupling thus also no AF and no weather sealing.
    Unfortunately, the lack of AF will be a showstopper for many photographers. Thanks to focus magnification and peaking, the lens is certainly usable without but it is probably more aligned to video use. The clickless aperture ring is also pointing to this. Overall it's a competent and affordable lens within its niche.
    • Optical Quality 7.5
    • Price / Performance 8.5
    APS-C E-mount Laowa Prime Standard
    8.0 September 29, 2026
    Nikkor Z 40mm f/2 Review
    Nikkor Z 24-50mm f/4-6.3 Review
