    Home » Tamron 20mm f/2.8 Di III OSD M1:2 Review
    Sony
    KlausBy KlausAugust 4, 2021Updated:August 20, 2026
    In our last part of our Tamron prime lens review mini-series, we’ll have a look at the Tamron 20mm f/2.8 Di III OSD M1:2 – probably the most interesting of the triple. It sits outside the coverage of standard zoom lenses and for photographers on a budget it can be a first step into the true ultra-wide segment. This doesn’t mean that there is much of a physical difference compared to its more moderate cousins (24mm f/2.8 and 35mm f/2.8). As mentioned already in the previous review, you’ll be hard-pressed to distinguish between them. However, this certainly helps in keeping manufacturing costs at bay. Ultra-wide lenses tend to be more expensive but Tamron managed to keep the price tag around a very moderate 300 USD/EUR – which is commendable especially for a full format lens.
    For this amount of money, you can’t expect professional-grade quality. The chassis is made of average quality plastics based on a metal mount. The rubberized focus ring operates smoothly but there is a cheap feel to it. Surprisingly, the lens has some seals making it moisture resistant albeit there isn’t a word about dust protection. While the length of the lens doesn’t change during focusing, there’s a moving inner lens tube. It isn’t fully clear why Tamron designed the lens to be relatively long because this tube is quite deeply recessed by about 1.5cm. A petal-shaped lens hood is provided.
    The AF system uses a linear extension system. Typical for this focusing type, the AF speed is on the slow side but it’s at least noiseless. The same can’t be said about the aperture mechanism. When stopped down, you can hear that the camera is opening/closing the aperture during focusing operations. Once again, this has a cheap feel to it. As usual, manual focusing works “by-wire”. The precision is pretty good in this case. A specialty of the lens is its close-focusing capability. It can focus down to a max object magnification of 1:2 (hence the M1:2 in the lens name). An image stabilizer has not been implemented which is hardly surprising given the price point.
    Optical construction9 elements in 8 groups inc. 1x aspherical and 3x LD elements
    min. focus distance0.11m (max. magnification 1:2)
    Dimensions73×63.5mm
    Weight221g
    Hoodbarrel-shaped with frame window (bayonet mount, supplied)
    Other featuresdust & moisture resistant
    The Tamron 20mm f/2.8 Di III OSD M1:2 produces an extreme amount of barrel distortion (~7.1%) in RAW files making the lens unsuitable for use without image auto-correction. It’s among the worst-performing full format lenses in this respect that we have tested to date. With auto-correction, there’s little to worry about here but it’ll have impacts on the effective resolution characteristic as we’ll see later on.
    The vignetting characteristic is typical for such a lens. Without auto-correction, the light falloff is heavy at just short of 3EV (f-stops) at f/2.8. Stopping down isn’t overly effective in solving the issue with almost 1.7EV of vignetting remaining at f/8.
    Activated auto-correction reduces the issue substantially by 1.5EV (f-stops) at f/2.8. The remaining light falloff is still visible but not drastic anymore. The vignetting is acceptable from f/5.6 in this case.
    The MTFs have to be discussed in two chapters this time. Let’s start with readings taken off RAW files first. The dead center is extremely sharp straight from f/2.8. There is a substantial drop in quality in the near-center zone already but the results are still very good here. The outer image region follows with good quality – which is commendable for such an ultra-wide lens. Stopping down is primarily boosting the resolution in the broader center zone reaching excellent results at f/5.6. The borders/corners don’t benefit quite as much with a good to very good peak at f/5.6. Diffraction has, as usual, a higher impact from f/8 and beyond. f/11 remains perfectly usable albeit on a somewhat lower level.
    The centering quality of the tested sample was good. Field curvature is moderate.
    The above is only part of the story though. Nobody is going to use this lens without distortion correction and this takes a toll on the resolution due to the required stretching especially in the outer image field. While the broader center is just marginally affected, the borders/corners are tanking in quality. Some softness is apparent at f/2.8 and the quality never exceeds good levels at optimal aperture settings. That’s still not bad for a 20mm but nothing to write home about either.
    CAs are very low with an average CA pixel width around 1px at the image borders. Lateral CAs can be eliminated via auto-correction without a loss in image quality so it’s not really an important aspect anymore.
    In order to achieve a shallow depth-of-field with a 20mm f/2.8 lens, you will have to choose very close focus distances. However, one of the features of the Tamron lens is its capability to focus down to just 11cm so there is quite some potential here.
    Out-of-focus highlights are circular in the center zone at f/2.8. The inner zone of the discs is just slightly busy and there is some outlining. The circular shape is mostly maintained at f/4 but the edgy 7-blades aperture is getting very obvious from f/5.6 onward and the outlining is also emphasized.
    The following sample crop illustrates the focus transition towards the background – taken at f/2.8. The bokeh is a bit more busy compared to the Tamron 24mm f/2.8 Di III but still alright for a 20mm lens.
    Sunstars
    The Tamron lens produces fan-like sunstars as you can see below – taken at f/11.
    When looking at the highlight discs across the image frame, the circular shape is maintained in a fairly broad center zone. As so often the discs deteriorate towards the corners but the effect is actually comparatively mild. Stopping down doesn’t really improve the already good rendering.
    Within the price scope, there is probably two direct competitor – the Samyang AF 18mm f/2.8 (shown to the right below) and Tokina FíRIN 20mm f/2 FE (center). The Samyang lens is slightly more expensive but more attractive (better) overall. The build quality is similar but the Samyang lens is substantially smaller and more lightweight. You can, however, expect fewer sample variations with Tamron lenses. The Tokina 20mm f/2 FE comes at about twice the cost of the Tamron 20mm f/2.8 but it’s also a full stop faster, has a superior build quality and is also better at medium apertures at least. There is, of course, also an offering by Sony – the Sony FE 20mm f/1.8 G (not shown). The Sony lens is the gold standard in this class but you have to pay extra for the privilege and the faster speed.
    60%
    60%
    The Tamron 20mm f/2.8 Di III OSD M1:2 is a bit of a complicated being. Obviously, it's not meant to be used without image auto-correction. Especially the massive (unusable) barrel distortion requires countermeasures. With all corrections in place, the center performance of the lens is just outstanding but there's a sharp drop in resolution towards the outer image field at f/2.8. The quality of the outer image field improves when stopping down and is decent albeit unimpressive at medium aperture settings. Lateral CAs are low. There is some vignetting at f/2.8 even with auto-correction but it's an acceptable compromise and fairly well-controlled when stopped down. The quality of the bokeh is good for an ultra-wide lens. If you have read our reviews of its cousins, you know already that we aren't all that thrilled by the build quality. The rather mediocre plastics and sluggish AF don't scream quality. However, in all fairness - this has to be seen relative to the low price tag. Keeping this in mind, it's almost surprising that the lens features some degree of sealing against moisture as well as an impressive close focus capability with an object magnification ratio of up to 1:2. Overall, the Tamron 20mm f/2.8 Di III OSD M1:2 is a good lens for a great price but it's not an obvious choice.
    E-mount Prime Tamron Ultra-wide
    7.5 November 16, 2026
