Samyang AF 18mm f/2.8 FE - Review / Test Report - Analysis
Ultra-wide angle lenses tend to produce a certain degree of barrel distortions and this also applies to the Samyang AF 18mm f/2.8 FE. A native distortion of 1.8% is actually quite good for such a lens. However, most users probably prefer to have image auto-correction activated in which case the distortions are negligible.
Vignetting is pretty much unavoidable in ultra-wide images - it's just a matter of how extreme it gets. In this case, it's quite extreme indeed with a maximum light falloff of ~3.4EV (f-stops) at f/2.8. Stopping down helps but even at f/8 the native vignetting is very high and visible.
With activated auto-correction the falloff is reduced by about 1EV (f-stop). This means that vignetting is still easily visible at f/2.8 but it's acceptable from f/4 at least.
The resolution characteristic of the tiny Samyang AF 18mm f/2.8 FE is pretty decent. The broader center quality is actually very good at f/2.8 but the borders and, more so, the corners are soft at this setting. This is not unheard of in ultra-wide lenses though. Stopping down to f/4 lifts the borders to very-good levels (albeit just) and the corners are good. The sweet spot is reached at f/5.6 with an excellent center and the corners have caught up with the borders. As usual, diffraction takes its toll from f/8 onwards and there's a visible drop in quality at f/11.
The field curvature is very low for such a lens. The centering quality of the tested sample was Ok.
Lateral CAs are quite good with an average CA pixel width of ~1px at the image border. Of course, image auto-correction can come to the rescue here as well so it's not really something to worry about in real life.
