Sony E 50mm f/1.8 OSS (SEL-50F18) - Review / Lens Test - Analysis
Lens Reviews - Sony NEX
The Sony lens produces a marginal amount of pincushion distortion (~0.3%) which is not objectionable in field conditions.
The light fall-off is quite heavy at f/1.8 (~1.6 f-stops) - this will be noticeable in most field images. Stopping down to f/2.8 eases the issue a little bit but it takes f/4 to reduce it to a negligible degree.
The camera sensor of the Sony NEX 7 has a rather difficult resolution characteristic for lenses specifically at large aperture settings - the corner quality is substantially dampened based on what we've seen so far. However, we still feel that it is appropriate to restart our Sony E tests based on this camera. After all this is Sony's flagship model (as of 2012).
The Sony lens is capable of delivering a very sharp center performance straight from f/1.8. This is the good news. The border and corner quality is rather soft here although the NEX 7 sensor has surely is share of responsibility for this. Stopping to f/2.2 lifts the border quality to good levels whereas the corners remain weak. There's a substantial increase in quality at f/2.8 with an excellent center, very good borders and good (just) corners. The peak performance is reached between f/4 and f/8 with a very good image quality across the image frame. Diffraction has an higher impact from f/11 onward.
The centering quality of the tested sample was acceptable but not superb. This is, unfortunately, something we got used to with Sony E lenses.
The Sony lens produces an average CA (color shadows at harsh contrast transitions) pixel width of around ~1.3px at the image borders. This is decent considering the extremely high pixel density of the 24 megapixel sensor.
It is nice to have a sharp ultra-large aperture lens but it is also important to have a very smooth bokeh (quality of the out-of-focus blur) which is simply part of the character of such a lens. The Sony E 50mm f/1.8 OSS delivers superb results here - which is really a rare quality at this focal length!
Out-of-focus highlights are rendered smoothly at max. aperture as well as stopped down. The circular highlight shape remains intact till about f/2.8. At max. aperture you can observe some shape deterioration towards the corners but this is quite normal.
The out-of-focus blur is buttery both in the image back- and foreground. It is seldom to have both areas rendered that good!
Bokeh fringing is a common issue with relatively fast glass. It's visible as halos of different colors in out-of-focus areas - magenta (red + blue) in front of the focus point and green beyond.
Typical for most fast primes, the 50mm f/1.8 OSS shows noticeable bokeh fringing at large aperture settings, which can of be reduced by stopping down. However, the effect remains slightly visible even at f/4.
f/1.8 f/2.2 f/2.8 f/4
