Pentax SMC FA 31mm f/1.8 AL Limited - Lab Test / Review - Analysis |
Pentax
Page 2 of 2
The Pentax SMC FA 31mm f/1.8 Limited exhibits only slight barrel distortion (~0.8%)
which shouldn't be really field relevant.
Note: We didn't retest this aspect because it cannot change just by moving to a different body using the same sensor size.
As a full format lens the 31mm f/1.8 enjoys a sweet spot advantage on Pentax APS-C DSLRs.
Nonetheless vignetting can be quite obvious at wide-open aperture (1EV). The problem is
gone by f/2.8.
The FA 31mm f/1.8 Limited produced excellent resolution figures in the MTF lab. At f/1.8 the center performance is already very good both in the center as well at the borders. The corners are a bit softer here. The quality increases a bit when stopping down to f/2.8 with a center reaching excellent levels followed by very good borders and corners. The quality remains exceptionally high all the way down to f/11.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are
very low for a wide angle lens. The issue shouldn't be really field relevant
with an average pixel width of around 0.6px at the image borders. You can force
the lens to produce some mild purple fringing (color blooming) at large aperture settings
and in extreme contrast situations.
The Pentax SMC-FA 31mm f/1.8 AL Limited is an excellent lens. It is already sharp
at f/1.8 and razor sharp from f/2.8 to f/11. Distortions and CAs are very well controlled. On the downside it vignettes quite a bit at f/1.8 so the ultra-large max. aperture takes its toll here. The bokeh (out-of-focus blur) is very smooth and buttery which is fairly unusual for a lens with aspherical elements. Typical for all Limited lenses the build quality is exceptional and it is a joy to use the lens. It also shares another, rather unfortunate, characteristic with its cousins - a high price tag. Quality comes at a price but 1200€/1000US$ seems a bit over the top but then it is probably just another example of diminishing returns upon higher investments. Nonetheless it is refreshing to see that Pentax
focuses on quality rather than costs - there're enough plastic lenses out there
after all.
