Pentax SMC DA 55-300mm f/4-5.8 ED - Review / Test Report - Analysis |
Pentax
Page 2 of 3
The Pentax lens exhibits negligible distortion at 55m. In the 100-300mm range you can expect a medium degree of pincushion distortion which may be visible at times in field conditions.
55mm |
100mm |
200mm |
300mm |
Typical for most lenses with an APS-C format coverage the Pentax lens shows stronger vignetting at max. apertures (~0.8EV). The problem is largely reduced and no longer field relevant when closing the aperture by 1 f-stop.
The Pentax 55-300mm f/4-5.8 ED is capable of producing quite respectable resolution figures throughout the focal length range. The center performance is generally on very good level with a rather typical quality penalty towards the long end of the zoom range. The border performance is a bit soft at max. aperture but the quality can be boosted when stopping down a little. The contrast in field images is pretty snappy - surely a positive effect from the ED element(s).
The tested sample showed an optical problem (centering) at 55mm which may have polluted the figures somewhat at this setting.
Imatest Explanations
Lateral CAs (color shadows at harsh contrast transitions) are well controlled (< 1px) between 55mm and 200mm. At 300mm CAs may be visible in critical situations though with a peak width of around 1.5px at the image borders.
