Pentax SMC-DA 70mm f/2.4 Limited - Review / Test Report - Analysis
Lens Reviews - Pentax
Typical for moderate tele fix-focal length lenses the Pentax DA 70mm produces only marginal (pincushion-)distortions (0.5%) - nothing to worry about under field conditions.
Regarding its APS-C image circle it doesn't really surprise that the DA 70mm f/2.4 produces some vignetting at wide-open aperture (0.86EV). At f/2.8 (just a third f-stop from the max. aperture) the problem is already a bit reduced and from f/4 onwards the vignetting is no longer field relevant.
As mentioned in the other pancake lens reviews this kind of lenses tend to produce a very even resolution across the frame and the Pentax DA 70mm f/2.4 Limited is no exception in this row. The center resolution is already excellent at f/2.4 whereas the borders and the outer corners follow on a very good level. At f/4 the quality is exceptionally high across the whole image frame and the peak is reached at around f/5.6. At f/8 the usual diffraction effects start to reduce the resolution again.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are almost a non-issue for the Pentax specifically at large apertures. The problem increases a bit starting at f/5.6 to an average width of ~0.5px at the image borders but this is nothing to worry about in field conditions.
As you may/will see in the sample image section the lens can also produce a slight degree of purple fringing (a color blooming effect) in extreme contrast situations.
