Pentax SMC-FA* 24mm f/2 AL [IF] - Review / Lab Test Report - Analysis |
Pentax
Page 2 of 2
The FA* 24mm f/2 exhibits a fairly low degree of barrel distortion (1.5%) which is
better than average for a lens in this class.
As a full format lens the FA* 24mm f/2 benefits from the usual sweet spot effect
on APS-C DSLRs. However, it is also an ultra-large aperture lens so it does still
produce quite high degree of vignetting at f/2 (0.89EV) even within this scope.
The problem is negligible from about f/4 onwards.
Pentax users may be aware of Bojidar Dimitrov website
where he mentions that the user feelings about this lens are a bit mixed. Well, I can
certainly concur here. The FA* 24mm f/2 produced a fairly similar resolution
characteristic like the recently tested Sigma AF 30mm f/1.4 EX DC.
The Pentax lens has a very sharp center performance straight from f/2. However, the
border quality is fairly dismal here. This doesn't really change till about f/4 where the
border resolution finally reaches good levels. The center resolution peaks at f/5.6 with
absolutely superb figures whereas the borders require f/8 to reach very good
quality.
It is worth to mention that the lens seems to produce a very high degree of contrast
even at f/2. "Sharpness" is a combination of resolution and contrast so subjectively
the image results may appear better than suggested by the graphs - probably one of the
reasons for the varying user impressions out there.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are not a
a real strong point of the FA* 24mm f/2. The problem reaches an average pixel width of
around 1.2px at the image borders. This is not a worryingly high degree but noticeable
at times.
The Pentax SMC-FA* 24mm f/2 AL [IF] is an interesting lens but not a really stellar
performer as you may expect from its FA* designation. The resolution characteristic has
a very strong emphasis on the center resolution whereas the border quality is a
bit substandard especially at large aperture settings. The delivered contrast seems
very high even at f/2 which may compensate some of the shortcomings on side of the
sheer resolution. The level of distortions is comparatively low for such as lens
whereas vignetting and CAs are about average. The build quality of the lens is
very good although today's Pentax Limited lenses are on par or even better
in this respect.
Optical Quality: |
Mechanical Quality: |  |
Price/Performance: | discontinued |
