Sigma AF 28mm f/1.8 EX DG (DX) - Review / Lab Test Report - Analysis
The lens shows a moderate amount of barrel distortion. This can be visible in critical shots especially with straight lines near the image borders. However, the distortion is uniform and easy to correct in post processing.
Typical for many fast FX lenses, the Sigma shows slightly pronounced vignetting wide open, which is reduced to practically irrelevant levels by stopping down.
The lens shows very good resolution in the image center wide open, which increases to excellent levels by stopping down.
The borders and corners are a very different story, though. Wide open, the values are poor here. The lens needs to be stopped down considerably to achieve significantly better resolution in these image areas. However, stopped down to f/5.6, the Sigma is able to deliver very good resolution even in the extreme corners.
Chromatic aberrations (color shadows at harsh contrast transitions) are well under control with values of below 1 pixel at the image borders throughout the tested aperture range.
CAs can easily be corrected in software or by the camera itself (most modern Nikon DSLRs remove CAs themselves if you shoot JPGs).
One of the primary usage scenarios for a large aperture lens is to separate the main subject from the background. In such an image the quality of the bokeh (out-of-focus blur) is of major significance.
The Sigma shows quite nervous bokeh both in front of and behind the focal plane at large apertures.
Background highlights also look quite nervous and in addition show pronounced outlining. Towards the image borders, they are cut off at large aperture due to mechanical vignetting.
Both the general bokeh quality as well as background highlights improve in quality by stopping down. However, with a wide angle lens one needs to get quite close to the main subject to still get a significant amount of background blur. The lens' very short minimum focus distance comes handy here.
Bokeh fringing (non-coinciding focal planes of the various colors) is a common issue with relatively fast glass. As you can notice below, the halos have different colors - magenta (red + blue) in front the focus point and green beyond. Truly "apochromatic" lenses don't show this kind of fringing but these lenses are very rare - especially below 100mm. Unlike lateral CAs, bokeh fringing cannot easily be fixed in post processing.
Typical for most fast primes, the EX 28 shows some amount of fringing at large aperture settings, which can of course be reduced by stopping down.
Move the mouse cursor over the f-stop marks below to observe the respective fringing
f/1.8 f/2.8 f/4.0 f/5.6 f/8.0
You can find some sample images taken with the Nikon D3x in our Nikon FX review of the lens.
The Sigma AF 28mm f/1.8 EX DG left us with a mixed feelings. The center resolution of the lens is nothing to complain about, while the borders and corners disappoint at large apertures. Stopped down, the resolution is very good across the DX frame, though.
Vignetting is a bit pronounced wide open, but no issue stopped down. Distortion is moderate and CAs are well under control.
The bokeh is quite nervous at large apertures, but improves considerably when stopped down a little.
The build quality is a bit of a disappointment because of the wobbling inner lens tube.
DX users looking for a normal lens certainly have several dedicated DX options nowadays that suit their needs better. That's especially true for those who own a motorless entry-level DX camera, on which the Sigma doesn't autofocus. Nonetheless, because of its very short minimum focus distance, the Sigma is an interesting lens to shoot close-ups, which is a very rare feature in this lens class.
Optical Quality: to
Field Quality:("regular" photography)
(Close-up fun)
Mechanical Quality:(downrated due to wobbling)
