Tokina atx-m 56mm f/1.4 X - Review / Lens Test Report - Analysis
As mentioned, the Tokina lens doesn't include a built-in correction profile thus you have to live with the raw optical performance. Eventually, you may see a correction profile in your favorite RAW converter but that's not guaranteed, of course.
The lens produces a medium pincushion of ~1.4%. While not ideal, this remains within acceptable limits for most applications.
The vignetting characteristic of the Tokina atx-m 56mm f/1.4 is a bit on the weird side. At f/1.4, the (raw-)light falloff is very moderate at just ~0.6EV (f-stops). Usually, this doesn't require additional correction. Stopping down to f/2 reduces this to 0.4EV. Strangely f/2.8 doesn't change much whereas the light falling is dropping a little at f/4 again. Our best guess is that there's either something going on under the hood or the vignetting distribution changes in a way that confuses our tool (Imatest). Regardlessly, there isn't really much to worry about anyway.
The Tokina lens provides a solid performance on a 26-megapixel sensor albeit it's not flawless. At f/1.4 the broader center performance is very high with a slightly reduced contrast. The border quality is weak although that's probably not a show-stopper in this lens class. Stopping down to f/2 lifts the dead center to excellent levels. The center reaches its peak performance at f/2.8. The quality of the outer image field increases gradually with decent results at f/2.8 and very sharp quality around f/5.6. Diffraction effects are getting obvious at f/11.
Lateral CA (color shadows at the image borders) are well controlled with an average pixel width peaking at 1.3px mark at the image borders at f/1.4. The CAs decrease when stopping down with the best results at f/5.6 and f/8. Overall this is a good result.
Purple Fringing
Tokina has an old enemy - purple fringing (PF). PF is a blooming effect at harsh contrast transitions. As you can see below, the issue isn't unknown to the 56mm f/1.4 as well. PF can be corrected (as shown to the right below) but it's usually a manual effort in post and not 100% perfect. Keep in mind that this is a rare effect and it's primarily limited to large aperture shots.
While sheer sharpness is certainly an important criterion, you rarely buy an ultra-fast lens for it alone. The primary application tends to be shallow depth-of-field photography and the quality of the bokeh should be a priority in your purchasing decision as well. So how does the Tokina lens perform in this respect?
Out-of-focus highlights are beautifully rendered in the image center with no outlining and a very smooth inner zone. A more edgy aperture shape is already visible at f/2 and it's getting more obvious from f/2.8 onward.
The images below illustrate the deterioration of the out-of-focus highlights towards the image corners. The circular shape is kept across a very broad image field with only an obvious deterioration in the corners. The corner highlight shape improves when taking shots at f/2.8 (other than becoming edgier).
The low vignetting figures, as well as the broad zone of circular highlights, suggest that the Tokina lens can cover more than just the APS-C image circle although it's probably not enough for full-frame.
The general rendition in the focus transition zones is smooth especially in the background. The foreground is slightly more edgy.
Bokeh fringing - also referred to as LoCAs - is a color fringing effect on the Z-axis. It shows up as purplish halos in front of the in-focus zone and greenish beyond. The effect is clearly visible at f/1.4 and f/2 and starts fading at f/2.8 - this is a typical behavior for a non-APO lens although somewhat higher than usual here.
