Canon EF 20-35mm f/3.5-4.5 USM - Review / Test Report - Analysis
Typical for many ultra-wide lenses the EF 20-35mm f/3.5-4.5 USM suffers from rather hefty barrel distortion at the wide end of the zoom range. The situation eases towards the 35mm setting where the lens shows a negligible degree of barrel distortion.
20mm:
24mm:
35mm:
As mentioned above the Canon lens is a full frame lens so on APS-C it can take advantage of the sweet spot effect. As a consequence vignetting is relatively low even at wide-open aperture. At f/5.6 the issue is pretty negligible.
The EF 20-35mm f/3.5-4.5 USM was very difficult to test. Under optimal conditions the lens is capable to deliver an excellent center resolution and very good borders throughout the range. This may come as a surprise because this is also partially better than the 17-40L but it really isn´t because the zoom range is rather conservative (1.75x ratio). You may also have noticed the rather diplomatic phrase "under optimal conditions" above. That´s because the lens generated some head aches initially. Usually the test results are obtained at a specific focus distance where the center performance peaks (compared to flanking focus settings). From here on only the aperture is varied. However, the lens freaked out a little using this produced because at the wide end at f/5.6 and f/8 the performance was lower than at wide-open aperture before rising again at f/11. This is typical characteristic of a so-called residual aberration - a focus shift dependent on the chosen aperture setting. We´ve seen this kind of behavior before - e.g. in the Canon EF 24mm f/2.8 - but it was quite extreme with the EF 20-35mm f/3.5-4.5 USM where the focus shifted a significant distance towards the camera (thus producing a slight out-of-focus effect). This is not so much of an issue when shooting landscapes but it´s a good idea to do a DOF preview at closer focus settings.
The MTF charts below show the lens performance taken at (almost) optimized focus settings to compensate the residual aberrations at the specific aperture setting (which is a little difficult).
Chromatic aberrations (color shadows at harsh contrast transitions) are very pronounced with this lens peaking in the average CA pixel width of ~1.4 pixels at the image borders. Not impressive but this is quite typical for zoom lenses of this range.
It is a little difficult to find a verdict for the Canon EF 20-35mm f/3.5-4.5 USM. The lens is capable to deliver a very high resolution which surely originates in the rather conservative zoom ratio. However, at the wide-end it suffers from very pronounced residual aberrations so you may run into situations where you cannot exploit the potential of the lens. If you´re primarily shooting landscapes with rather long focus distance settings this will not be much of an issue but for at closer settings you should either choose a small aperture (f/11) or do at least a depth-of-field preview check. Other than that the lens performed according to its class. The zoom range isn´t all that attractive on APS-C DSLRs but it may be worth a look for 1.3x or FF DSLRs (not tested in this scope).
Price/Performance:discontinued
