Canon EF 100mm f/2.8 USM macro - Review / Test Report - Analysis
As expected for a fix-focal lens and especially for a macro lens the level of distortion is absolutely negligible.
On the EOS 350D with its reduced format (APS-C) the (full format) lens exhibits moderate vignetting at f/2.8 which disappears from f/4 & up. Expect more vignetting on 1.3x or full frame cameras.
The lens was tested twice but only to obtain data beyond f/8 which was missing in the first review. The MTF differences between the two tested samples are insignificant.
Typical for most macro lenses the EF 100mm f/2.8 USM macro performed highly impressive in the lab. The lens is already very good in the center at wide-open aperture with marginally worse corners. The lens reaches its peak performance at f/5.6. You shouldn't stop down beyond f/16 due to the limiting effects of light diffraction.
The quality of the bokeh (the fore-/background blur at large apertures) is smooth. You need to be a little careful regarding lens flare with this lens - using the hood is a good idea especially with streaking light.
Similar to most other fix-focal lenses chromatic aberrations (color shadows at harsh contrast transitions) are very low and nothing to worry about.
