Canon EF 24mm f/1.4 USM L - Review / Test Report - Analysis
The lens shows slight but still visible barrel distortion.
On an APS-C DSLR the EF 24mm f/1.4 USM L enjoys a sweet spot effect here. However, this doesn't seem to be enough to produce low vignetting at max. aperture. Admittedly f/1.4 is a rather extreme setting specifically for a wide-angle lens but the vignetting shouldn't really exceed 1EV on an APS-C camera. At f/2 the problem is already reduced to a very acceptable degree and from f/2.8 the issue is negligible.
The EF 24mm f/1.4 USM L showed two different souls in the lab. The center performance of the lens already good to very good at f/1.4 increasing to superb resolution figures from f/2.8 onwards where it easily reaches and probably exceeds the resolution limits of an 8mp sensor. Unfortunately the borders aren't quite as good. At f/1.4 they are soft and it requires f/4 to reach very good territory which is relatively "late". The border quality peaks at f/8. The resolution characteristic at the borders is slightly disappointing for a fix-focal lens with this price tag.
CAs (visible as color shadows at harsh contrast transitions) can reach an average CA pixel width of around 1 pixels at the image borders - an acceptable performance for a wide angle lens but again a little disappointing for this specific lens.
